  4. Points between points
7 Posts 3 Posters 376 Views 2 Watching
  • Arjan de Vriesundefined Offline
    Arjan de Vries
    Is there a possibility to insert a waypoint some down the route without becoming the last point. So if you have 100 points can I put one between 30 and 31 for example?
    • Arjan de Vriesundefined Arjan de Vries
      Nick Carthewundefined Offline
      @Arjan-de-Vries If you’re using the route planner in the app, a long press in between route points will add a new route point in sequential order.
      If you’re using the website, hover the mouse cursor over the route line until you see the black ball, then click.
      MRA Navigation Next and SilverFox B8J bar buttons.
      Quadlock wireless mount for IPhone 11.
      Cardo Scala Packtalk Bold.
      TomTom Rider 500. (In the cupboard now)
      Arjan de Vriesundefined 1 Reply Last reply
        Arjan de Vries
        @Nick-Carthew mmmm.. I think I am doing something wrong here. When I am in the app on the iPhone or iPad and want to insert a waypoint it gives me the last number and langpress does not work. See picture.![alt text](Schermafbeelding 2025-01-05 om 10.01.22.jpeg image url).
        If I press the yellow button it puts a waypoint where I want it but it will be the last number (in this case I wanted one between 2 and 3 but it gives 115.).
        white.mouseundefined Nick Carthewundefined 2 Replies Last reply
          white.mouseundefined Offline
          @Arjan-de-Vries To insert the new point correctly, you must first place the new point on the route between the points where it should end up and then you can move it to the correct position!
          met een R1250RT met TFT en BMW Connected Ride App; de Garmin Zumo XT en My Route App in combinatie met de Carpuride W702 (voor Android op de Motor!)
            @Arjan-de-Vries Do not use the yellow button, long press on the route line to add a new route point.
              @Nick-Carthew Look at my example between route points 2 and 3. A long press and I can add a new route point 3 and the old route point 3 now becomes 4.
                Arjan de Vries
                @Nick-Carthew WORKS! Thanks!
                Arjan de Vries
                • New beta! 4.4.0 (400)
                  CD130undefined
                • Looking for a Route from Roermond to Ijmuiden, Netherlands?
                  Rob Veermanundefined
                • NAV 6 Craziness
                • 12 Tage in den Seealpen mit MRA und es war eher NICHT gut..
                • Route en avance sur la position
                  LE DIZES Freddyundefined
                  LE DIZES Freddy
                • De geplande route even verlaten, kan dit?
                • Scherm indeling MRA routeplanner
                  Robinekeundefined
                  Robineke
                • Scenic routing & RouteXpert library improvements
                  Edwin_Mundefined
                  Edwin_M
                  2.0k
